Blower motor issues
Ross6132
04 Chevy 2500 blower don’t work I have replaced blower and resistor still nothing I have power to the motor even with Ignition switch off and power to only one wire the red one in the blower motor harness
Voltage does not = power.
Did you test your old blower by supplying power directly to it?
Did you test your new blower by supplying power directly to it before installing?
I try to test new parts before installing. It can save a lot of grief.
I also test old parts. Even if I have no plans for using them again.
Always test a fuel tank sending unit before installing. I relearned that on the 1995 Tahoe.
Yes I tested old and new parts with a jumper wire directly to them and they both worked fine
And I’m not sure about the dedicated ground I know if I put a jumper wire on The ground for the blower it will run
