block heater location
It most likely would be where the center frost plug is on the drivers side.
Had new injector pump installed and truck running like new. Thanks guys... New problem...ac is fully charged and cold. Sometimes clutch engages and other times had to tap clutch with rubber hammer. Now clutch not working either way. Is there way to test if ac coil bad or just clutch bad?
There is a certain clearance that is supposed to be between the clutch and pulley. I don't know it off the top of my head. WarWagon or Aceneights should know. They are into A/C.
