Chief915
915A Maint Tech
I've kinda been waiting on it to happen for the last couple months and it finally did last week. 252,000 miles on the clock, a hot heath chip, 15ish psi max boost, qutie a bit of towing, etc. I remember gettting on it pretty good Wednesday night and it ran geat. Thursday morning I went to breakfast and it started fine, ran great, nothing out of the ordinary. But when I pulled into the parking spot and stopped I noticed a grey/white cloud blow past the front of the truck. After breakfast I kept an eye on the tailpipe while I started it. It spit and sputtered for a few seconds with a nice ploom of whitish/grey smoke, then cleared up and ran good the rest of the way home. When I got home 10 miles later the low coolant light was on, a steady haze from the exhaust, and the upper radiator hose was bigger than normal and was hard as a rock !!
I tore it down Saturday and Monday, the passanger side gasket is the one that went, between the back two cylinders. I did have a little problem, one head bolt on the drivers side broke off when I was breaking it loose. Luckily about 1 inch of it was sticking out of the block once I got the head off, a stud remover got the broken piece out of the block.
I continue to be amazed at how good this engine looks internally for having 252,000 miles on it. It barely has any ridge at the top of the cylinders, and you can still faintly see the cross hatch on the cylinder walls.
I am going to go with a set of studs when I put it back together, hopefully that will keep me from doing this "fun" job again on down the road. I may need some prechambers too while I am in there. I have only looked at one head so far, but 3 of the 4 precups have cracks that are longer than 1/4". I would love to find a good set of diamond precups somewhere.....
