gulfyankee
1994 6.5 TD, extended cab dually. 127,000 miles. 3" straight pipe, aftermarket air filter. Started have boost surging issues at cruise...ie....at 70mph steady speed flat surface the boost would fluctuate from 2-6 lbs every 5 seconds or so. bypassed the vacuum system and made a turbo master, set at 12 lbs max. This other problem started a little while before that happened. Getting a good bit of black smoke at takeoff. MPG has dropped about 3 MPG average. Seems to take longer for the turbo to spool up (higher rpms) I used to be able to power brake it and build max boost and no smoke, now no boost and alot of smoke.....
So am I looking at replacing the turbo, IP, injectors, PMD, or what? I feel like it is dumping too much fuel.....
