Black smoke at slight or high acceleration stumbles at idle
wlrdlr49
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _It smokes black at the slightest increase in throttle. after driving & coming to a idle in gear it shakes like its missing.It also stutters when going up or down any size hill. The trans shifts in & out of overdrive at speed.___________________________
- Year: _1998_____
- Truck model and class (ie: c2500) c3500_________
- Automatic or Standard auto__________
- Mileage: (indicate miles or km) _89K________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _pmd relocated,removed cat,#9 resistor,perf. air filter__________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? turbo______________
- Ambient outside temp: (indicate *C or *F) _any_________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __1 or 2_______
- What fuel additives are you using? _lucas sometimes__________
- Where are you located? _Illinois____________
- Air filter _today________
- Fuel filter _2 months________
- CDR Valve? __???_______
- Coolant – last flushed/replaced at __never___________
- Oil – synthetic/regular, changed at _regular 3000K__________
- Batteries – state of charge, (matched set) replaced at _new____________
- Battery cables and grounds (removed, cleaned and tightened): __recently____________
- Glow Plugs - how many miles on them? _88K________ What type? __original___________
- Injectors - last changed at _never______________
- What were you doing when it happened? _driving_____________
- How was the truck running fine before this problem appeared? __fine___________
- Has this problem ever happened before? _no______________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __y__ And? __no______
Diagnostics:
1] Starting:
1a] Does the engine start? __yes_______
1b] Does the engine crank over? __yes______
1c] Are your batteries fully charged? __yes_______
1d] Have you removed, cleaned, and tightened all battery connections? ___yes_____
1e] Does your Wait to Start light come on for a time? How long? _few seconds________
1f] Does your glow plug light come on? _yes________ For how long? __few seconds_______
1g] Do you see smoke from the exhaust while cranking? What color? _no_______
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ____yes_______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _remote__________
3b] Condition of Extension harness (if used) Vendor or Homemade? _homemade________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. __good_______
3d] PMD Make: _stanadyne__________
3e] PMD Age: __unsure used___________
4] Stalling Issues
4a] Do you experience stalling only when hot? __n/a__________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) __n/a____
4c] Does pouring cool water over the IP seem to help with restarting? ___n/a______
4d] Is stalling momentary (engine recovers)? ___n/a______
4e] Does SES light come on when engine hiccups? __n/a_______
4f] Does cruise control quit working when engine hiccups? __n/a_________
4g] Does re-starting seem to reset engine, restoring cruise and power? ___n/a______
4h] Changes to dash lights or instruments during stalling events? ____n/a_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __no_____
5b] Any bubbles or oil film in coolant overflow tank? __no_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __no________
5d] Excessive white smoke from exhaust on cold start? __no_______
5e] Excessive black smoke from exhaust under hard acceleration? __yes________
6] Performance Issues
6a] Do you have gauges? ___no________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ____no__________
6d] Have you changed exhaust / downpipe / crossover? _removed cat_______________
6e] Wastegate – mechanical or vacuum? _unsure_____________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
_________________________________
__________________
I am sure someone more knowledgeable than me should pipe in soon, but have you checked your vacuum pump? Where are you in IL?
No I have not. What kind of things do I check it for? I live in Pawnee 10 miles south of Springfield.
Take off the belt and turn it with your hand. That is how i found out mine was toast. It was real easy to turn.
If you are using the factory vaccum system, which i assume you are, with the truck running try and move the wastegate rod on the turbo. It should be quite hard to compress. If it moves easily, you have a loss of vaccum which could be attributed to a leak, bad solenoid, or a bad vac pump. Start by checking all your vaccum hoses for cracks or splits and go from there...
If you have a vacuum guage, you should be getting around 15"hg at the wastegate, or about 25"hg at the pump. But by the sounds of it you have enough vacuum to have a correctly operating wastegate.
I see that you have relocated your PMD. Where did you move it to? Did you move your old one or buy new? who's did you buy? Make your own harness or buy one? If yours is reloacated on-top of your intake, it should be moved to another location, preferably outside the engine bay.
Mine did the same thing and it was the egr valve...you can test it by unplugging the vac hose from the egr and pluggin the vac hose with a golf tee and electrical tape or even better, a screw.
take it for a spin and see if that does it.
its the pancake looking canister on top of the intake underneath the cover. it has a rigid vacuum hose attached to it. remove the vac hose and plug the hose.
Well things have gone from bad to terrible ! It won,t hardly run now. Shakes & shudders & belches black smoke.
bought a used PMD & moved it to the front bumper area. I made the cable.
When did you install the PMD/FSD and the homemade extension cable?
Did you move the ground wire from the top of the IP when you replaced the PMD?
You reported it got much worse..............Any news?
