curt
Have a slight hmmm going on with my 6.5, it rattles harder on Bio, have been making my own for over two years now and running in several different rigs, this is the third of my own an am still running in a 90 5.9 Dodge.
I keep my tests to a fine edge I like a good process a good wash and filter twice after wash 20 micron to a 10 micron both fuel filters, and into a fuel tank with a tank filter there it is another 10.
My wash is just 5 percent water wash to make sure to get methanol and any soaps left then a four hour air wash to make sure alcohol is gone.
Like I said have run it in others and did have a Duramax that did well the 5.9 loves it but the 6.5 gets louder on it and quite noticeably,
My Son in Laws 93 runs well on it and also veggie nice and quiet but not so my 98, any ideas? Now to details of my rig
98 K3500
NV4500
1164xxmiles
serviced in the last 1500 miles Engine oil 15w40 Amsoil
Fuel filter at the same time
Filter was a bit sticky from the sub zero weather this winter but not bad some stuff in bottom of canister but no big deal
Did replace an exhaust valve about four thousand miles ago head bolts and throw out bearing at that time also
Do need to replace return lines have a leak on the right side putting off till I do the injectors. Trying to find another set of turbo types so can have them redone and just do a swap.
Still need to get EGT gauge and boost still working on it, lots of projects
so no info on temps there bummer that.
Any ideas? Would trying to feed it more air help? It sounds more quiet with ulsd kind of baffles me my other rigs went the other way on Bio and this one while it gets decent mileage on it, just short of 18 mpg in combination driving (freeway and city) , and runs fine starts well even cold, cycle the glows and light her up, just a couple of times over.
I think I have covered it it seems to run alright just noisy. Maybe worrying about nada.
Thanks Curt
98 K3500
NV4500
1164xxmiles
Thanks Curt
