GM Guy
Manual Trans. 2WD Enthusiast
Hey guys,
The project 98 K2500HD had a bad alternator, and a really crappy charge wire setup, which I want to correct.
So I wanted to ask you guys, what guage should I use, and how important is it to use a fusible link? is there any pre-made offerings? I see PT wiring solutions does not offer a seperate charge wire on his site, maybe Bruce offers it if I ask nicely.
Also, I am kinda "electrically challenged" so now for the dumb question: what could occur in the pickup's electrical system that would cause the alternator to burn out?
The previous alt. was a bigger framed alt (the CS144?) that was not factory, and it was cobbled in, the stub harness was adapted (IIRC one loose wire) and the charge wire may not have been making the best connection.
Basically i am a little gun-shy about sticking the new one in till I know why the old one failed.
Finally, for testing purposes, and sort of a poor mans fusable link, can a guy use a 12 guage wire to make sure the system works?
Any input appreciated, thanks!
