iamdave0887
Here Comes Chaos.....
Long story short i responded to a craigslist ad that was local for a free 6.2, only thing i si have to help remove it form the truck. No big deal since there's no front clip on the truck at all. Fenders, hood, inner fenders all gone.
So this morning before i leave to look at it the owner calls me and said "i can't turn the engine with a 1/2" drive breaker bar...at all." Great so it's seized. The engine hasn't run in 3 years, but was running when the truck was parked.
I know the best way is to tear it down and see what's stuck, but i don't have the time or the money to reassemble it properly right now with new gaskets, headbolts/studs, etc etc.
I get there and we grab the breaker bar again and this time put a piece of pipe on the end. Before we even tried to turn it, i knew it was locked up real bad. It didn't budge even a 1/4 inch. I checked the oil, it was low but there was oil in it and no signs of water in the oil. Inside the air filter housing was a nice mouse nest and the EGR valve was really rusty with signs of water getting in.
On the bright side I'm also getting the 14 bolt 3.42 rear axle from the truck for free. It looks to be the FF but with the hubcaps still on i couldn't tell for sure. Will make a nice upgrade for the blazer once i come across a Dana 60 front end and swap to 3.42s.
Anyways, what's the best way to un-stick this engine? It'll be a spare that'll spend it's life in my shed until needed, but i'd like to know the engine at least turns over before re-arranging everything in my shed to make room.
I've heard one can fill the cylinders with marvel mystery oil and let it sit for a while then remove the injectors or glowplugs and attempt to turn it over. Are there any other ways you folks know of?
