TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
Hi guys,
On the way home yesterday with the Tahoe, a loud squealing sound was coming from under hood.
I got the Tahoe home and popped the hood. I could see that the vacuum pulley was intermittently getting stuck, and the serpentine belt was slipping against it and squealing.
Oh boy. Well, I read the threads (like a good forum member) and read up on vacuum pump removal and replacement options.
1) I realize I could get a TurboMaster setup and just ditch the whole vacuum pump setup.
2) I could replace the vacuum pump throw it back in, and just keep driving.
I am leaning towards answer 2, reason being that cash is tight (common problem
) and if I put in a TurboMaster, I'll want full gauges to see what's going on. That would mean probably 400+ in more parts.
If I just follow path 2, I can just get by with the stock setup and keep on driving for now. I found that NAPA sells a pump, NAPA Part #64-1009, for around $130. I think its the right one. I need to get this thing on the road this weekend if at all possible, otherwise I'd be ordering from one of our valued vendors.
Anyway, here's the question. I got the vac pump out after wrestling for awhile, and found out that GulfSurfer's experience is the same as mine: http://www.thetruckstop.us/forum/sh...rt3-Vacuum-Pump-Removal&highlight=vacuum+pump
Here's a shot of the pulley. And finally my question: Exactly how do I remove that bad boy? And then get it onto the new pump?
Thanks guys,
-Rob
Thanks guys,
-Rob
