DIESELDAVE
Lets hear what ya got to say fellas
shave the pistons and then recoat them
been done quite a few times, just don't get rid of the swirl chamber. It won't take much
dave, he is talking about the ricardo swirl chambers on the tops of the pistons......the tops of the pistons can be shaved down between .020" and .040" (depending on original piston portrusion). This will get you in the neighborhood of 18:1 compression. This will lessen the depth of the swirl chambers, but not too drastically. Really needs to be calculated to get exact, but is not necessary. The idea is to lower the compression so asa to be able to add more boost with less stress on the motor.
Another method, is to shorten the connecting rods. This way the pistons do not need to be modified at all.
We have used mls gaskets (multi-layer steel), some like them some do not.
The fourth that can be used (as gm did) to lower some, not all, is pre-cup modifications.
In our present build now, we are using a combination of piston and pre-cup mods (looking for 17.5:1)
I was under the impression they stopped making those 18:1 pistons
I would un shroud the valves right up to the fire ring. Kills two birds. Lowers compression, improves head flow. A fly cutter for gassers could be adapted. Is the 6.2/6.5 valve stem the same as some common gasser? BB Chev?
ive found several sets of them so far
actually noLet me guess they're all oversize
A similar principle is used in some hot rod gasser engines. They call it a 'zero deck' build using flat top pistons, zero deck height and 'thin-ish' HG's.
