zielinski.family
What timing chain have you thought was best? Cloyes? Federal Mogul (Sealed Power)? S. A. Gear?
if I were gonna spend some coin to do the timing chain I'd go Phazer and get gears. There are varying opinions on gears from harmonics will kill an engine to best thing they ever did for the engine. Ed
I'd be afraid of gears grinding or binding and wearing the teeth down, which would cause some symptoms similar to chain clop. That's what i would assume could happen.
From what I've seen most oe timing chains will still be in spec a 250,000 miles. If you replace that chain it should last another 250,000 miles. Do you really think a gear drive at 4 times the cost of a chain is really going to make much of a difference? Would your engine last long enough to justify spending that much for the gears that would outlast 3 or 4 engines?
