ak diesel driver
6.5 driver
My choices are pan or the output line.
Pressure port would be pretty hard to get to
That is where mine is, It is done by feel.What about the pressure tap port on the side of the trans?
Your gmtdscantech is reading sump temp via the temp sensor in the pan, the pressure port I'm pretty sure is right after the pump and should be close to where the fluid is the hottest. It wouldn't surprise me to see upwards of a 75 degree difference when you're really working it hard. I know my ALLISON runs 80-100 degrees hotter for the fluid coming right out of the pump going to the cooler than the fluid in the sump going into the pump.
It is a 1/8" NPT plugFerm, Is that a 1/8" NPT fitting on the side of the housing?
I can't recall who it was (over a decade ago), but someone told me that wasn't the best place to read the temperature from. I was told it would be better in the pan, but best on the output line. Since I didn't want to cut a line, I opted for the pan, since I have a drain plug there, anyhow, with the same size port (for the cost of a bung kit, it's silly to not install one). I'd love to have it in a place where I didn't need to mess with a wire every time the transmission is serviced, but wouldn't want to compromise, either. Are we talking about the same port?
It would also be nice to not have a wire hanging off the bottom of the pan. I've never had an issue, but it still isn't an ideal situation, in my opinion.
My GMTDScantech read 20* lower than the gauge while towing.Your gmtdscantech is reading sump temp via the temp sensor in the pan, the pressure port I'm pretty sure is right after the pump and should be close to where the fluid is the hottest. It wouldn't surprise me to see upwards of a 75 degree difference when you're really working it hard. I know my ALLISON runs 80-100 degrees hotter for the fluid coming right out of the pump going to the cooler than the fluid in the sump going into the pump.
If so would it really make a difference where the sensor is as long as your temp at the specific location is within those parameters?Depending on where the sensor is put, (test port, pan) and so on are there specific temps that the fluid should be at for those locations?
