Big T
I have Napa premium brake rotors on the '99 and they're warped (2nd time) from all the mountain driving I do. I'm looking for the best rotors for mountain driving and towing. Drilled? Slotted? Cryogenic? Willing to pay up to avoid warping.
I have about 35K miles on this set of brakes and CV axles. The CV axles are Dorman remans. The LF boots have only 4 ribs with a flat spot, while the RF boots have 6 ribs. The LF boots cracked in fairly short order and the outer is now leaking. The RF boots are fine. Rockauto had some new CV axles that were about $25 more than the Dorman remans a d we installed those on Colby's '94. They're nice. I'll replace the LF axle with one of those.
The brake pads are about 1/16" away from the feeler on the LF side. The RF brake pads have more meat on them. Always wondered what is causing the uneven wear, as there is no pulling to one side when braking. Should I consider replacing the calipers?
The brake backing plates have cancer from their prior life in Illinois. I have solid backing plates from the '94, but they're in place on the steering knuckle as we could never get those bearing bolts out. I'm going to soak those knuckles in a bucket of ATF for a week or so and then go at them with the impact wrench.
Fun stuff.
I got the 3rd row seat from the '95 wreck sold and the guy is coming back for the 2nd row seat. He's local and he's installing them in a beautifully restored 1969 Suburban. Colby wants the AC blower motor from the '95 as the one in the '94 is starting to make noise. So we're really down to harvesting the engine, Trans, transfer case, front differential and rear axle, then we tip that pig over onto a flatbed and haul it away for scrap. Never have found a buyer for the doors, even at $25 apiece.
Fun stuff.
