Jasondt2001
Lead Slacker
I had a drawtite timer based controller before this one. Being that I haul live loads I wanted it to be the most comfortable ride i could give them back there.
The thing I didn't like about the time based controller was it never felt the same when braking. I know alot of people run these and are happy with them but i swear I don't think i could ever get it set up to run right :cuss:
Everytime I came to a stop sign and then took off the trailer would buck a bit and it made me nuts.
One day i went out and hooked everything up and it refused to recognize the trailer until I shut the truck off and turned it back on then smacked it arounda bit :incazzato:
I figured with upwards of 10k pounds behind me safety wise that was not acceptable.
So on to the brake controller search I went. I really wanted to stay away from the tekonsha because (I know this sounds bad) but the name sounded so chinese...
I kept reading review after review about what a heaven send this thing was and then I knew i had to try it out for myself.
I ordered my Prodigy P3 and the wiring kit (I HIIIIIIIGHLY recommend getting the wiring kit for it, what a SIMPLE install!) from the internet.
In about a week (they were slow...lol) I got it to my door. Come to find out they sent me the Prodigy, NOT the prodigy P3. I really didnt have time to wait so I told them just to refund the different and I'll try this one.
It's MADE IN THE USA Come to find out. Tekonsha is the city it is made in I read!
I've never installed a brake controller, and to be honest I was terrified.
Got under the dash, pulled off the plastic cover on the wiring underneath and unhooked my old drawtite.
mounted my prodigy, plugged in their harness, and finished my install in about 5 minutes - no joke. I LOVE that harness :yesnod: Now, it was a bit long wire wise, so I just wrapped the excess up under the dash and haven't had any problem.
ok, on to the good stuff...
I have towed 2 different trailers since then and couldnt be any happier if i tried.
My stops are great and slow. Not jerky and bumpy. I've heard people say that they can't tell the trailer's back there - Now OBVIOUSLY you can tell it's back there w/ my LQ trailer but honestly, it finally stops right. I'm no longer pulling up to stop signs with white knuckles praying she'll stop before the line.
I come coasting in, apply my brakesand it stops right at the first white line!
Now in panic stops, I have NO worries anymore, my truck and trailer stop STRAIGHT with no pushing or swaying now, MUCH safer!
I've also towed a small 2 horse bumper pull. Unfortunately I thought I could leave it at the same setting as the big trailer... :smilielol5: It did GREAT the full 150 miles until I decided I NEEDED to stop for this quick yellow light.
All i can say is, have you ever looked in your rearview mirror and watched a trailer BOUNCE 3" off the ground? I have 10: I'm still suprised my horse loads :ihih:
Once I get it set up for that small trailer though, that one you would't know is back there, it's THAT good!
To set them up, what you do is go on a flat road (Back road) turn the p3 up about 1/2 way. Do 25 mph and with your hand apply FULL brakes to the prodigy, if the trailer locks up back it down. Keep doing that until you can apply FULL brakes on the prodigy w/out the trailer brakes locking up.
Then you're set up.
So the cliff's notes are, if you've thought about it, try it! I LOVE mine!
Then you're set up.
