rtquig
Can the Batteries on the Dmax be tested while connected or does one of the positve cables need to be disconnected so you don't read the voltage from the other battery?
Take them both out or disconnect both and load test them. That's the best way.
I took my truck in to Orschleins, a regional farm type store, because the batteries that were purchased there seemed to be weak. They have some kind of electronic gizmo they hooked up on the terminals. It measured the voltage, temperature, and CCA, then printed out a ticket saying if the battery was good or not, based on the battery model which was entered. He tested both batteries, hooking up the cables on one side, then the other while the cables were still connected. They did the same test last fall, and gave me a battery as a result. The truck is a '93 GMC.
