3500GMC
What T F, over
Well I did it. I will have to remove the RR tire and a bed side brace to R+R batteries (should only happen every 5,6,7 years anyway) and the cables (2/0) will be a little more involved. But alas, the batteries are kicked out of the engine bay. Basically is a tray that is welded to a pair of 1/4" thick brackets that bolt to the front spring bracket and the bed/cab bracket. It's not going anywhere.
Some careful measurement landed them in this spot. They are the OEM size but the ones pictured are the dual terminal. My new set will be side post only. The top posts WILL clear the bed cross braces underneath.
I had to make 3 long SS 1/4" bolts that can be removed from the underside. No other fasteners to fumble with for hold downs.
Under the hood the main OEM battery cable was cut and re-attached to the backside of a post mounted in the old air intake opening to facilitate jump starting and charging. This also is where the now upgraded 8 AWG accessory feed is wired in. This wire supplies the terminal strip on the firewall which is the main wire for the electrical system.
At the main starter lug (solenoid) the new 2/0 cable and existing OEM battery cable is fastened.
Will follow up with the underside pics (bed on) of the battery tray.
