This is probably a dumb question. but I would like to understand basic automotive threads better. for example, I'm replacing a fuel filter and lines on a 95 cavalier. the fuel lines are rusted to I'm replacing them all. My question stems from when I replaced the fuel filter I got the correct stock replacement that has a 3/8" slip on connection for the filter inlet, and what is listed as a 16mm x 1.5 female outlet. I'm refering to a fram G7315 (used on many cars).
So my question is what is the correct fitting to use on my new 3/8 steel fuel line tuning that runs from filter to engine? Is this a tapered pipe thread. When took apart the old filter it has a flared tube with an "o" ring. I also noticed that a standard 3/8" nut from 3/8" brake line threads into this but didn't seal.
do I need an SAE 45 flare fitting, pipe, or inverted flare?
any help on this topic would be greatly appreciated. thanks
