Rodd
Recruit
I just pulled the barn door actuator because it stopped working. I went to kragen and they want $60 for it. The kid there said to go to an auto alarm shop and they sell them for $15 but you have to splice in the 2 wires. Has anyone done this? I also want to test it w/ a multi meter to make sure it's good because I noticed the rear defroster is using the same power as the actuator and it doesn't work either. What do I set my multi meter at to check for continuity? Also what is a good reading?
Also the key hole on the barn door is stuck and won't work I sprayed some wd40 in it but it's still stuck. Any thoughts?
