GM Guy
Manual Trans. 2WD Enthusiast
hey guys, I ran the PN from heaths article (the 88894035) at GM for a price, the number had been replaced by 19168609. price of 454.80 . Ouch. anyways, took the numbers, hit rock auto, and there is two pumps.
pump 1 description: ACDELCO Part # 251603 {#12456231, 19168609, 88894035} OE Design; Stamped Steel Impeller
PUMP KIT,WAT W/GSKT, PULLEY
pump 2 description: ACDELCO Part # 252776 {#88926290} Does Not Include Mount Bolts
PUMP KIT,WAT EXTENDED CAB; 2 WHEEL DRIVE; PRESSED-ON PULLEY FOR THREADED FAN CLUTCH
PUMP KIT,WAT CREW CAB; 2 WHEEL DRIVE; PRESSED-ON PULLEY FOR THREADED FAN CLUTCH
PUMP KIT,WAT REGULAR CAB; 2 WHEEL DRIVE; PRESSED-ON PULLEY FOR THREADED FAN CLUTCH
so the first one matches everything, so I will probably go with that, but is the second pump different? it is more than 50 bucks cheaper, that is why I ask. but the preferred 88894035/19168609 is still half of GM, so I will still be happy with it at that price if it is the better choice.
there were other brands, but I figured delco is what I should stick with.
any input appreciated, thanks!
