aggar
Don't tear it up!
On the duramax there's the tab that you're supposed to ground the jumper to while trying to jump start something. Mine doesn't ground out. Can't get it to spark with the other one. Any ideas why this isn't working??
What's wrong with hooking it up directly to the negative terminal on the battery? That's what I've always done and never had any problems.
Yes, you are correct. There is always the possibility that explosive hydrogen gas could be surrounding the battery and a spark would cause an explosion.You want to remember when jump-starting a car is that a slight possibility of explosion does exist. This is because hydrogen gas which forms as a battery discharges is flammable, and a spark from the battery cables could set it off. It's a slight because the gas would have to be fairly dense around the battery for this to happen. This is unlikely unless the battery has been sitting for a long time and little or no air circulation has occurred in the area, but it is possible.
Take the Ground Connection off, and scrap off the paint down to bare metal at the mounting point.
GM had a brain fart.
