Matt Bachand
Depends on the 6.5
Just thinking about this... what would happen..
What would happen if you had a turbo installed so the engine's intake air stream would spin the turbine, and by spinning the turbo the other end would suck the exhaust out, causing negative pressure or a vacuum to suck out the exhaust gasses
Something to ponder!
