ATT oil drain tube cutting
Gekkoen
Norway
I just got the ATT i ordered from leroy and i have started to plan the install, but i cant figure out where to cut the oil drain pipe.
where do i cut it, and do i cut a section out or just cut it to two pieces?
if anyone that has done this could chime in it would be helpful :)
it cuts into 2 pieces i believe 2 inches down from the top of the drain tube. The kit will have a 3/4 inch rubber hose (I believe) which will connect the two pieces once you cut it.
That is an engine out picture so maybe it looks different with the engine in? 6.2 heads on a 6.2 block with 2 manifold gaskets to clear the injectors is also different. YMMV.
it will be a while till i can get the turbo installed, as my summer vacation is ending this coming weekend
but i think i have figured it out, i think i was just overthinking it.
and thank you Leroy,
everything has gotten here now.
the only things i have installed so far is the fuel pressure tap and the boost bolt.
I looked at mine tonight while changing my oil. about 1/2 of what you have in your pic
