Paveltolz
Доверяй, но проверяй
Admittedly, the ATT mileage increases others have reported haven't fully materialized for my truck. Maybe my driving style and it don't match well but regardless, with the use of the A/C, numbers have reversed from mid to high 16s down to as low as 15.4 mpg.
History: When I first got the truck in 2007 and drove it across the country in January (pretty much OEM everything). I would see a freeway norm of 17 mpg and that had to be on winter blends (WA, ID, WY, UT…you get it). City mileage, after getting to NC was 15.9 to 16.5mpg. Doubtful we had winter blends in the Sand Hill region though.
Four years later...this winter I have conducted 5 test runs for extended periods on the ATT and GM-5 comparing driving conditions and winter to summer fuel blends. I did change computer tunes mid way through the first test period but didn’t see a noticeable change with either the ATT or the GM-5.
ATT numbers to date have been:
16.81 November to December (mixed driving)
15.51 December to February (GM-5, new tune, no change from last year)
16.9 from February to the first part of May (mostly Daily Driving),
16.32 for the rest of May (mostly Daily Driving) and
17.02 this last weekend on a road trip to Vega BUT...,
I anticipated some good numbers with constant freeway speeds, the lower altitudes/denser air but with the A/C on, that didn’t really happen.
Freeway speed driving down and most of the way back was 75mph with AC on for the first four tanks.
Worst tank was descending out of St George UT to Vegas and driving around town; 15.4 mpg. Climbing out of Vegas was 15.8mpg. Best tank was the last one with the A/C off and slowing to the sweet spot of 70 mph (2200rpm) with some back road driving for a while at even lower and very inconsistent speeds; 19.34 WOW.
Still, without the high numbers for that last tank, considered it a fluk, the trip would have been closer to 16.5mpg and I know that since I'm back to my Daily Drive, the numbers will be back down around what I'm seeing after test run 4 which was 16.32 and those were without the A/C being run.
So, regardless of the mpg improvements you've had with your ATT swaps (good on ya) has anyone else seen their ATT equipped trucks take an MPG hit with the A/C on or am I just special?
Another question for the field, has anyone not seen their MPG numbers increase with summer finally coming on this year? Mine seem to be even less from the winter.
