Any doctors in the house?
nookiemonster
mississippi
: Explain your problem in concise language (ie: Cranks but won’t fire).truck turns over and will start after awhile..only after running during hot weather i/e leave work during the day stop to eat lunch and truck will turn over but difficult to start__________________________
- Year: 1996______
- Truck model and class (ie: c2500) k2500_________
- Automatic or Standard automatic__________
- Mileage: (indicate miles or km) __240,000k_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _ssdiesel pmd module 2/3 years ago________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __believe it is a s model it only has 1 solenoid for the wastegate actuator___________
- Ambient outside temp: (indicate *C or *F) __hot 90 plus degrees_______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __no.2_______
- What fuel additives are you using? _lucas diesel treatment once a month_______
- Where are you located? _mississippi___________
- Air filter _every other oil change 12000 miles________
- Fuel filter _every 4-5 months________
- CDR Valve? _last year________
- Coolant – last flushed/replaced at _hate to say but at least 4 years____________
- Oil – synthetic/regular, changed at _chevron/delo__________
- Batteries – state of charge, (matched set) replaced at _good 1 year old____________
- Battery cables and grounds (removed, cleaned and tightened): _yep_____________
- Glow Plugs - how many miles on them? originals______ What type? _____________
- Injectors - last changed at _originals______________
- What were you doing when it happened? __n/a____________
- How was the truck running fine before this problem appeared? _yes___________
- Has this problem ever happened before? ___yes____________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __no__ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? _yes but takes a while______
1b] Does the engine crank over? _yes_______
1c] Are your batteries fully charged? _yes________
1d] Have you removed, cleaned, and tightened all battery connections? ____yes____
1e] Does your Wait to Start light come on for a time? How long? _yes about 5 seconds________
1f] Does your glow plug light come on? __n/a_______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ________
1h] Does the Service Engine Light Glow during Start/bulb check? ________
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? __yes_________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _on top of manifold cover_________
3b] Condition of Extension harness (if used) Vendor or Homemade? _vendor________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: _ssdiesel__________
3e] PMD Age: ____3 years_________
4] Stalling Issues
4a] Do you experience stalling only when hot? _very hard to start___________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______________
6d] Have you changed exhaust / downpipe / crossover? ________________
6e] Wastegate – mechanical or vacuum (OEM)? vacum ______________
7a] Single or dual thermostats? _single___________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? _no___________
7d] Have you replaced the fan clutch? Manufacturer of replacement? no________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
__Basically cranks runs fine all of the time in cooler weather..seems after summer hits 90 degrees or so..will crank fine in the mornings, but if i run it for a while and need to stop and turn off engine, it is very hard to start...will turn over and over and over then will catch and crank...its been doing this for a few years, but i only drive it to work and just never got a firm diagnosis... put a new pmd on and that didnt seem to help much if any... lift pump was replaced last year on the frame....could it be the OPS switch? I know I need new injectors and plugs just as a preventative thing....truck runs great and pretty good pep for a truck 14 years old...just this cranking issue after running it in hot weather...no diesel peeps here except dealers and really dont feel like giving them my money when I could possibly fix myself...just need a firm diagnosis.._______________________________
Open the T valve on the coolant crossover manifold while running and check fuel flow, if you can put a psi gauge on it and check fuel pressure.
Get the PMD out of the engine bay as soon as possible
Are you certain it cranks just as fast when its warm? Or even faster? Hot batteries and battery cables can cause high resistance and starter might not crank as fast.
Check lift pump pressure when idling as NVW says.
Otherwise there is a common hot IP hard start problem. And to check the next few times try pouring a bottle of water over the IP before cranking when hot. If it gives you no problems like that its likely an IP issue.
I'm sort of curious about the amount of time you let it sit before trying to start it again, and how warm the engine is...
After you try what the guys above are thinking, if you haven't found anything, I'd like you to try pulling off the CTS plug (it's the coolant-temp sensor, located in the thermostat housing) before you try to start it.
See what happens. The CTS sends a signal re: engine temp back to the PCM, which controls glowplug on-time... when it's cold, you get lots of time. When it's unplugged, the PCM sees the temp as -40 and gives maximum time. The other thing it does is advance the timing a bit to make it easier to start; if your timing is a bit retarded (timing chains stetch over time), then your truck will start hard without being advanced again.
If it doesn't help, you lose nothing. Put the plug back on.
If it does, then you need to see if the issue is bad sensor or if you need to be re-timed.
Jim
Thanks for the quick info guys, I appreciate it. Will try all of the above...Couple of questions, how much water to pour on the injection pump. What should my fuel pressure be running at the t connector?
Probably not the problem, but you should replace your glows and injectors after you figure this out. Overdue....
