matuva
Tropical 6.5er
the guy stop, parked his truck on the side of the lane and key off.
He talked with his friend during less than 1/2 hour, said goodbye
came back to his truck.
WTS, key on, and ... nada. Not a puff of smoke, not even a hiccup, just the starter spinning, engine spinning too, but nothing
After he killed his batteries, he finally get towed home, luckely less a kilometer far.
Found a good battery and bought a new one, asked his friend with another K1500 to have batteries hooked in parallel, and while the other truck was reving up to 1500 rpms, they tried to start the beast.
Starter spinning strong, but still nothing.
They called me. I did usual test :
LP is good, plenty of fuel at the T-valve, no air flooding at the fuel filter valve.
All fuses OK
Fuel solenoid is clicking, cracked an injector while crancking, get fuel at injectors.
Tested the glow plugs : all good, glow plug relay is fine too.
PMD is less a year, a D-Tech, relocated in front of radiator, behind the grille.
I hooked my laptop with AutoEnginuity soft. No codes !
PMD did quit suddenly ?
As there's no codes, could it be the CPS or optic sensor though ?
All fuses OK
