treegump
Romans 3:22-24
Haven't lost complete hope, but I thought I'd post this just for anyone looking. I'll delete it if I change my mind...
My truck: 1996 Chevy K2500 silverado, power everything, 2 door ext. cab, LB, 4x4, 5 sp (NV4500), 6.5L "F" turbo diesel, 203k miles
Looking for best offer. Don't NEED to sell it, but would/am considering it. I've spent a lot of time and money in this truck, so I should keep it, but I'm also interested in finding something with a solid front axle and a bit more clearance...
Brand new batteries
Custom 5" Straight Pipe after downpipe
Hideaway gooseneck hitch
Rear bumper hitch
Pyro Gauge
Boost Gauge
Custom front hitch with fog light mounts
DIY wastegate
A/C delete
PMD relocated to front bumper w/ heat sink
Air Filter modded after the '97
South Bend Clutch (not even a thousand miles with it)
FTB mod,
FFM relocated to side of intake
High-flow crossover
High Idle switch
(will include fuel gauge - inline part already installed)
Will need tires. Still some tread, but not much. I have 1 brand new tire (revo retread with sticker still on it), but didn't want to replace the tires till I fixed the truck.
Ball Joints replaces 50k miles ago, wheel bearings replaced ~20k miles ago, used injectors were tested and set by MDI in crown point & glow plugs replaced ~20k miles ago
Reason I'm considering on selling it is because I'm tired of working on it. Currently has a leak in the fuel filter manager, and the motor shuts off randomly. It has good fuel flow, so could be PMD or could be the injection pump...or... I don't need to sell it, nor have I given up all hope, but thought I'd see if anyone would be interested.
I found most/all my mods on www.thetruckstop.us .
I may be interested in a ford or dodge 90's or newer truck, with manual transmission, 4x4, diesel with a solid front axle. (Size cab can be extended or standard, and bed can be flat or standard) Wanting a running work truck that I can get firewood, and haul/pull stuff with. I know, a lot to ask for with a currently non-running truck, but like I said, I don't NEED to sell the truck, just checking really. And if I could find a loan, I'd do a partial trade. Could be nothing at all, but won't know till I start crossing things off. Fuel is getting to the fuel filter housing. And supper was cooking, so I didn't get to investigate further than that.
No low balling - its not scrap. And I'm not interested in parting out.
Brand new batteries
Rear bumper hitch
Pyro Gauge
Boost Gauge
DIY wastegate
A/C delete
FTB mod,
High-flow crossover
High Idle switch
