alternator questions
just a number
Active Member
Trenton ON
Changed the dash over and was having the fun job of rewiring. you'd think the look the same, they should be plug in an go. but no. I ended up with a 12v line going back into the voltage 'sensing' wire and now it only read 1.2v when off and 4v when running. Now the big questing is, what did I fry? :confused:
doing anything with wires makes me want to do this repeatedly :mad2:
Wish you luck! :thumbsup:
