SSduramax
should be workin'...
I was out checking my property lines this morning and ran over a stick :mad2
about 3 feet long and about 3 inchs thick). Well, it popped up and did a number on the shifter linkage, under the rubber boot looking thing between the crossmember and where the linkage attaches to the side of the trans.
It works fine to go from gear to gear but will not go into Park. the wire?? seems like it is bent, I can grab it and manually get it to go in Park and it straightens out. Then I can go through all the rest of the gears but not to Park again.
Is there something under that boot that might have bent?
Pics on the way.
Pics on the way.
