All 4 on Hi Relays Not Working
Big T
Fullerton, CA
I get Lo beams. I get Hi beams. But the All 4 on Hi stopped working. Checked fuses in both relays and they're fine. I'm running HIDs in Lo and Hi, so this All 4 on Hi is a needed function.
You can, but when you do, it puts the load of all the lights on 1 relay, and that is not an ideal setup. A cheap diode does the trick, and keeps it so the relay's are only poweri,g 2 lights at a time.
I`ll have to check it out. i was thinking with the high beam for the signal and the low beams bulbs hooked through the load side of the relay, it`d be powering just the low beams.
If you wire it so the lows are on 1 relay and the highs on a another relay, you normally use a diode from the high beam relay to the low beam for the all 4 on mod. Now you can also wire it so the high beam relay powers the floating pin of the low beam relay for the all 4 on, but this method has all 4 being powered off the high beam relay. Don't know of how else you could wire an all 4 on.
