BIGR
Lucky To Be Here
Since my fuel mileage seems like it was going to crap, I decided to purchase a new air filter and try that. I bought an AC Delco Air Filter at the dealer (Part NO. A3087C) for about 52 bucks. When we opened the box I noticed the filter had 2 parts to it. The main filter itself and then a small rubber ring that is about and inch or two wide. It appears that the one end of the filter fits into that rubber ring. It seems that the rubber ring is made to seal off the intake tube on the exit side of the filter. Other words to force all the air through the filter and prevent air and trash from getting past the filter. One of the guys at the parts counter said that the rubber seal ring is not always used, so that got up my curiosity. He said you will have to read the instructions to see. I read them when I got home and it said to use it. I was thinking that the older filters were a one piece filter with the seal ring on the end. Maybe that part number was A2947 I don't know, because the is the first time I have installed a new air filter in my 2006 Chevy.
Tell me if I am on the right track on this. Also it appears that the installation would be pretty simple, any pointers on installation or anything I should watch out for?
