how much R134A freon does my 95 suburban hold?
I serviced the freon today set the high side to 150psi and the low side to 30psi. I noticed that when I had the a/c on the compressor would cycle on and off, when I would turn on the a/c for the back passenger the compressor would not cycle on and off. is ths normal operation. the pressure did not change when the back was turned on and off.
