Seriously, bad kick out switch. Charge 134A recovered was very close to spec. This was during the FI cleaning. Fan on speed 5, rec, idle at 1200 RPM. The over driven aggressive engine fan is useful out here. 85 degrees out and 3/4 the way into the garage with no helper fans.
Looked at ice on AC lines and knew why it always dumped water when I started it the next day. The evaporator ice would melt and fan the next day would blow it out the drain...
