If it is integral and can't be replaced how come when you buy new hubs it doesn't come with ABS sensor?
On an 8 stud you need to remove wheel bearing assembly to access the ABS sensor. You can buy sensor separate, some hubs come with, some don't. Sometimes just the wires are pooched...
I just checked the wheel bearing and it's not that, so that's a relief. I guess I just need to find a deal on the sensor.
