Big T
Where I last left off I had taken the '99 Burb in top pull codes for the ABS. Codes indicated the RF sensor did not have conductivity, or basically was out. I replaced the sender and the ABS worked for a couple drives before the ABS light came on again, basically staying on since then. Typically, the ABS light comes on after I start rolling forward after starting up.
Had the Burb out on a road trip this week. We were doing some off roading in the desert and I noted the ABS light was off. Sure enough, ABS was working, this was over several miles of rough driving. When I got back on the pavement, I said aloud "it typically takes a couple seconds and the ABS light will come on." This time it took about 10 seconds for it to come on and it stayed on the rest of the trip, which was about 1,200 miles, mostly highway, with some off roading.
Obviously, the ABS pump works when the light is off. Senders on both sides have been replaced twice. Bearing have about 12K miles on them. Desperately would like to figure this out. If it's not the senders, then is it in the harness going to the ABS pump? If so, how do I test for this?
