Big T
Would like to get the ABS working. Went back to the last time I took it to the dealer to be scanned and it had 1 current and 9 history codes:
C0221 - RT FRT Wheel Speed Sensor Circuit Open (current)
C0222 - RT FRT Wheel Speed Signal Open
C0223 - RT FRT Wheel Speed Erratic
C0225 - LT FRT Wheel Speed Open
C0227 - LT FRT Wheel Speed Erratic
C0265 - Drop Out Both Frt Wheel Speed
C0267 - EBCM Relay Circuit
C0268 - Pump Motor Circuit Open
C0268 - Pump Motor Circuit Shorted
C0281 - Stop Light Switch Circuit
I know the last one for the stop light was a bulb out and that was fixed.
The Left Frt Wheel Sensor sensor cable came loose and was frayed through and that was fixed. I've replaced the RF bearing with sensor and no change.
Lot of stuff going on here and I don't know where to start.
