ABS light on....sometimes
Drago
Active Member
Virginia
ABS light is intermittent but there is no problem with braking, just to may sure the brakes don't go flakey on me I pulled the ABS fuse. Of course the light stays on but unless I'm on slick stuff I should be ok, maybe.
I heard about a ground for the ABS light that might need cleaning, anybody know where that's at?
When the ABS is plugged in, does the ABS still work?
How would you know if it was working or not? with or without the fuse in, I step on the brake and it stops without pulling or grabbing
