Danish Farmer
Hi gyes
On my Silverado, 1995, the ABS light has started to come on at some point every day, but disapear again after some minutes.
Brakes are working fine, but some times the pedal will feel hard and make a surring noise. Like it will not sink as deep as it use to, and kind of vibrates and feels hard to press enough to make a short stop.
Hub assemblyes in the front are only two months old, and pads and one caliber was changed at the same time.
Fluid-level is at MAX, and there is no connection between when the light is on, and when the pedal acts like described above.
What could be wrong ?
Regards,
The danish Silverado-owner
Regards,
