gnel
How are these working? Do I need a new harness? Will my old heat sink work? Old resistors work? I´m on my last (of 5) PMDs. Thanks folks. gus
Add to that the temp swings in cold climates: go from say 20*f outside to underhood temps and you have a huge temp swing that may happen several times a day. We continue to monitor PMDs in real time both under hood and bumper mounted. Bumper mounted is allways cooler.Mine, an older rev 2 slightly modded has been on my IP going on 10 years without issue. Going through 5 is nuts and points to a potential IP fuel solenoid issue or as they say poppetitis!! Generaly caused by bad fuel agents contaminating the IP and siezing up the solenoid. P1216 P1217 are ussualy the codes that will follow in time along with 1000 bucks or so for the enevitable replacement of the IP. As you might imagine this puts a lot of stress on the PMD power transistors which are a pair of inverse mounted MJ15004g darlington emitter type transistors. The bells on these get hot under normal loads approaching 150- 170f. Even a small increase in amp loading can put these up to pooling temps for some solder types and in there lays one of the many issues. Couple that with those same temps or higher after vehicle shutdown and now the PMD is fighting 2 resistive based isssues from an electrical standpoint. I find i get the best run temps on the PMD mounted to the IP which is around 126f going down the road. That means fuel running through the IP is soaking up some of the heat. Problem is as soon as you shut down the underhood temps go through the roof. My measurements are based on a meat probe i use to poke around in varoius areas under the hood.
FWIW Dtech is made by Flight Systems.Been running a DTech for nearly three years now.
No issues.
Its just so much more reliable, especially if the zombies learn how to set off a emp!
:thumbsup::rofl:
What do you do about the starter and "E" trans :rolleyes5:
I wonder what it would take to make a PMD out of Vacuum tubes, I see the the two large power transistors but not to sure about the rest. Vac tubes would solve the EMP and heat issues
