Ama83
So could the tunacan be removed and fumes routed with hose under car or does it need to be there?
It's only there cause the tree huggers wanted it there.
The 95 in my sig has high blowby and has been without it for the last 80 thou km.No leaks observed as of today.
Oil use has nearly disapeared.Was using a ltr oil in 3-400 km,now 3 ltr between oil changes
If your crank seals start leaking after,then you got bad seals to start with.
my 2c
Lots of blowby and the road draft tube can make your truck look like it is on fire. Any specific reason for messing with it? You have other things to work on under the hood...
They are easy to test.Suspecting that is stuck open, quite a lot oil at turbo and oil is disappearing somewhere from engine. I really wouldn´t like to pay 100$ for that item...
