Hink
Overkill Is Underrated
Hello all,
Recently I was told that the CS144 will not work with the 4L80E transmission because "the F terminal output is a different signal ratio than a standard CS144, and the 6.5L relies on the F terminal output for transmission control and a couple of other features.".
Also, "Any high output CS144 unit that you purchase from anyone will likely have a smaller than stock diameter pulley in order for the alternator to charge well at engine idle RPM. This changes the F terminal output to the TCM, and makes the transmission shift incorrectly. "
Has anyone ran into this? It seems that many have done the conversion and I don't remember any problems with the transmission reported.
Thanks!
Thanks!
