Brooklyn Tow
9 11 Never Forget
OK two problems.....Changed all the lines that got damaged from the accident. The big top line that goes from the compressor to the bottle/dryer, I replaced that with a line I had from the 99-2000 sub gasser, it looked pretty much identical and bolted right on.
Turns out when I put the new condensor in it had/has no orifice valve.....will the system operate without the orifice?
Also when I went to charge the system it took freon (134a) started to cycle but didn't seem to circulate then the compressor stopped working and the head unit shorted out.....replaced the head unit, same deal compessor started to work but not seem to circulate and shorted out head unit 2.
Is it the big line I put on is wrong/clogged high/low pressure switchs are bad? the compressor clutch has a little wobble to it (from the accident I guess).....could the internals of the compressor be pooched and not letting the gas circulate and/or can the compressor be shorted as to be burning out the 2 head units....It's hot and humid in NY and before this accident the A/C worked fine.
HELP!
HELP!
