MGILBERT18
- Messages
- 59
- Reaction score
- 0
My A/C will blow cold air for a while and then it like the heater gets turned on. It only seems to do this if I have the temp controls set for very cold. If I set it just into the blue section of the temp controls, then it will usually be ok, but if I move the temp controls to about midwau into the blue, then it will switch over to hot air blowing out. The snowflake stays lit. The blower never stops blowing air the cooling changes from cold to hot. If I turn off the ignition and restart, the air will begin to blow cold again. It resets and the whole process will start over untill it gets real cool and repeats whe whole process. Does anybody have any suggestions before I take it in to the dealership??
