iviper123
Recruit
my ac isnt working my clutch engauges but it cycles on and off real quickly and when it engauges my rpms drop by about 300rpms, seems like a big rpm drop
Just did a evaporator 4th of July weekend on my 98 K1500 truck 2# freon was what was called for on the sticker, and GM service manual, 3# for my 98 burb with rear air, 4# is too much. Truck is cooling down to 40F on a 80F day, 52F on 95F day
4 cans=48 oz/16=3 lbs
That is assuming you got every drop out of the can which you don't. There is only a small amount of pressure in those little cans, unlike a 30 lb'er. depending on what the sticker says. Every truck is different. Go by the sticker on the a/c box.You really wanna do it right you should scale the cans. Although I don't htink I know anybody that does. I scale the 30lb'er.
theres mirerust/corrosion, nothing major on just discolered.
can i test the wires going to the clutch? to see if that is working properly
when i first turn the ac on the clutch stay on for a little while than start tho on of cycling
if your saying low pressure switch on the drier can than yes i have jumped that switch and clutch still engaues and dis engages as before
You might have a bad high pressure switch that is pulling out too soon (I don't know if this is a typical problem or not). What are your pressures when you get the cycling? I picked up a cheapo set of AC gauges from Harbor Freight just to be able to work on my various rigs. Really helpfull for diagnosing what's happening.
i got a hold of a set of gauges today i had got a a low side of 45-20 cycling
and high side of 175-275, i added more 134 and it went to 325 at its highest low side never changed, whith the ac off i got low side 60 high side 60
