Rodd
Recruit
Okay I read through the 2 most recent posts on A/C. Here is what I have done thus far....
The A/C worked last summer and fall however the front didn't work great but worked and when I turned on rear with it, it worked great. Now to this year. The compressor doesn't kick on until I connect a can of 134 and then it only kicked on after about 10 seconds after connecting the can.
Filled it w/ 24 oz and it ran okay for a day then nothing. Put a can of sealer/dye and nothing w/ the glasses and black light. Today I put a 14 oz can of freon, sealer, oil, dye and it worked okay.
I bought the vacuum pump from HFT as well as the a/c guage set. Hooked them up and pressure was at 27. I disconnected the high pressure disco and air started coming out no freon. I put the quick connect back on and used the pump to purge the system and no freon came out just air.
It is stuck at -25 now and hasn't moved for an hour. According to the book since it doesn't change there is no leak. The high pressure connection on the truck has a little pin inside that I am assuming is stuck. What do I do next?
Thanks
Thanks
