Its getting hot again and the past couple days I have needed A/C.
I wanted to check with the experts to see how you do it and how do you know how much 134 to add and if I am doing it right.
I have allways hooked up the gauges with A/C on high, low side needs to be 30 psi and high side not over 150 psi. I add 134 until low side is 30 psi and call it done.
Am I close?
Am I close?
