MAGNUM SERVICES
Intelligence Guided By Experience
Bought a 94 GMC Jimmy S15 and the Blower Motor only works on Low/Medium, not High. ALL Fuses good as is the Fusible Link, NEW Resistor/Relay/Motor but NOT Switch, any ideas?
I will check my fusible links again, Thank You for the replyGood parts don't mean they were the first new parts out of the box you tried...
Blower motor spins at any other speed - it's good. High current draw from a bad motor can damage the skimpy GM wires and connectors. (Even a good motor can in some cases.) Possible bad ground that fails at high speed current. Test blower motor to good ground for voltage. Take action on anything over 0.5v.
Start at the high speed relay - does it have 12v power and a 12v signal to the relay coil? Good ground? Jump the relay and see if the motor runs.
No 12v coil signal at high speed - wiring back to the switch and test switch.
Fusible links are good because you tested for voltage right? They can break from age with no burn marks.
