dazed
- Messages
- 139
- Reaction score
- 7
OK I heard a noise the other day under my hood and upon further investigation it turns out its from the A/c Compressor. The noise was happening with the A/C off (unplugged all winter and barley ever used). So I hook up the A/C (plug it back in) and engage clutch... NO MORE SOUND! OK so I at least isolated the problem. Upon further looking at front of clutch plate i see small metal fragments. I found out that i have a clutch puller (nice) and proceed to remove the nut ....NO NUT! Okay then I look at gap between clutch and pulley and really couldn't see any (like it was almost touching. So I pull the clutch off and now no more noise...Great but I think I would like to use the A/C some time this summer so I'm in the need to repair this. Upon further looking at the back of the clutch I noticed that half is shiny (were it was rubbing) and the other half dirty. Also there was a bunch of dirty dried up grease in the hub... and I Spun the a/c pulley after removal and feels good (unlike before i pulled the clutch)...no real slop either.
So what happened and how can I fix this? I don't believe the pulley had walked out since the circlip is still on it. I don't quit understand that If i reinstall the clutch and give it 20-30 thousandths of clearance and then install a nut tight (with the clutch and key ) wouldn't that pull it together thus touching?
Also is the clutch supposed to spring back somehow after power is shut off...and thats what might be happening?
Is a clutch kit with the pulley my only option?
I'm kinda afraid if i go pulling the pulley off I might either break a seal in the A/C or rune the magnet or bearing since I probably don't have the Correct Puller.
Is there a way to put the clutch on without a puller..or would tapping it in risk damaging the bearing....
Thanks For any help...sorry for the long post and many questions
Also anybody know the correct nut size and pitch...im guessing its metric...1/4 -20 looked about right but wasn't and the threads looked a little tighter than 20 pitch
