DennisG01
Noticed my AC wasn't blowing cold (this was the first time I had it on this season), so I pulled over and saw that the clutch is not engaging. When I got home I removed the 2-wire plug (on the AC), cleaned the connections and re-plugged the connector back on (actually unplugged and plugged a few times). Still nothing.
I disconnected the plug and measured volts at the plug with the engine running and the dash button "on". The black wire measured a solid 14.2 millivolts, while the green wire's reading fluctuated wildly... between 300mv and 1.3v (the best that I could tell, anyway, as it was fluctuating rapidly).
I can move the clutch by hand, fairly easily. All battery cables/connections are clean and tight.
Am I correct in thinking that I should trace the wires (black and green)? Does anyone know right where they go? Chilton's does not cover the AC system.
Any other advice?
Any other advice?
