GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
I scored a 1998 GMC K2500HD RCLB 6.5L auto 4wd. definitely a fixer upper.
It runs very rough, and seems to be missing pretty bad. There is no blowby, so I am hoping it is not in the engine. Vaccum pump locked up and shredded the belt, so I need to change the belt and the vac pump so the computer can at least get a tach signal.
PMD has beeen relocated, harness has all black wires, but the heatsink looks alot like Leroy's. IIRC a black stanadyne PMD. it is in the grille. I switched it out with a known good PMD and it doesnt change anything at all.
Here are the codes:
P0126
P0183
P0251
P0606
P0126P
P0183P
I need to get the belt drive operational, and clean grounds and proceed from there, but I was wondering if anyone has allready been down this road and found it to be a bad IP.
Any input appreciated,
Thanks!
Here are the codes:
P0126
P0183
P0251
P0606
P0126P
P0183P
Thanks!
