lsshewolf88
My 98 6.5f is thowing a code PO2036 It calls for turbo boost censor I just replaced it a day ago drove it , light went out now its back on calling same code again any 1 else ever have this issue ? I have replaced every thing on this truck but the turbo its self, just put new IP , timing gears ,chain, censors batteries, alternator, and wire to alternator, im not sure what can be causing this code also the code is a generic from auto zone so it has turbo boost censor , ECM , and some kind of circuit problem, but when I change out the turbo boost censor the light will go out so im inclined to think some thing is causing the censor to short circuit or some thing else is wrong that's the code it keeps messing with ? ty in advance for the help
